B2710 HST 2003 transmission no power to push
wcross
2003 b2710 kubota front loader and backhoe attachment
Oct 9, 2022
Massachusetts
Bought a 2003 B2710 with 1100 hrs. Changed hydrolic oil and filter, cleaned suction line strainer refilled to proper oil level. Moves forward/reverse in low range, barely moves mid range, will not move in high range. When trying to push front loader into pile to scoop has no power to push forward to scoop up material. The hydrolics to front loader and backhoe operate fine. Any suggestions appreciated.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
237
85
Jefferson, Ohio
You need rev up the engine. The petal selects the gear ratio. You don't run a car up a steep hill in 5th gear at 20 mph. Just push the petal down a little bit so you are in a lower gear ratio.
GBJeffOH
Nov 17, 2014
237
85
Jefferson, Ohio
SDT
multiple and various
Apr 15, 2018
3,260
1,049
SE, IN
Tractor should move in any range with engine at idle.
Did you use the correct oil in the HST? Did you use the correct filter?
If so, symptoms indicate serious HST damage. How did the oil that came out look? How did the filter look?
Was the purchase price a "great bargin?"
wcross
Oct 9, 2022
Massachusetts
Yes, correct oil and filter, from dealer. Old oil looked clean, strainer had metal particles on it. Great purchase price..?……no don’t think so.
ferguson
L3130
Jan 19, 2022
296
115
w.v.
HST is bad / went through this with my l3130 same symptoms had to replace HST got a used one on line / pull the filter and cut open checking for bronze
hodge
Nov 19, 2010
2,905
453
Love, VA
How did it behave prior to servicing?
2,995
It’s a shame, when people come here and ask for help, and then fail to reply in the end, to say whether they came to a solution, or they’re still struggling
ferguson
L3130
Jan 19, 2022
296
115
w.v.
Structural Pull & cut the filters this will tell all you need to know. Hope there clean & it just a adjustment. Good luck.
