Hi - My B2650 dashboard has an LCD screen in the middle, and LED indicator lights surrounding the screen. The LCD screen and all of the LED bulbs are soldered to a single circuit board. One of the LED bulbs---- the green left-turn signal bulb ---- does not work any more. I've removed the circuit board and tested all of the solder connections, and everything else is working except the left-turn green LED. I contacted the local Kubota dealership and they informed me that they aren't able to order any of the LEDs. Instead, I would have to order the entire dash for approximately $450 CAD. Has anyone had a similar problem and found somewhere to order a replacement green LED which can be soldered to the circuit board to replace the one that is not working? Any assistance would be greatly appreciated. I bought the tractor new a few years ago, so it's no longer under warranty. Thank you.
