B2650 cab joystick hits steering wheel
mpham
B 2650 cab
Nov 15, 2016
152
Massachusetts
Anyone else have a B2650 cab that the joystick hits the wheel when you try to dump the bucket and lower the arms?
I tried tightening up the cable on the stick end. Seems like there is a lot of play before it moves anything. Might have to remove the seat in the spring and see what it looks like under there.
Mine has a different knob I think as it has a switch for the 3rd function valve.
Any ideas?
2,581
Any ideas?
On the BX - (different that what you have) there is a linkage with a nut that can back off the bolt creating a lot of slop in the movement of the stick.
Something has loosened up - so you might need to get to that before spring;)
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
394
57
Wa
I have noticed the same thing with using my snowblower.
Left on the stick hits the wheel and the 3rd function buttons, too.
I have learned to feel it and move it without hitting the wheel.
I will look into the ability to tighten or adjust it.
Orange1forme
Dec 1, 2018
394
57
Wa
Here is what I found today, a missing nut.
I had found a nut on the floor a few weeks back, but did not find its home.
Now I have.
The nut runs out of threads before it pulls the actuator shaft tight to the bracket. I don't know if there is something else missing or it is supposed to be that way.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Judging from that round witness mark I'd say a washer goes there.
SRG
B8200D 4WD........ JD 870, FWA, 300x FEL.......... JD 797, 72" Z-Trak
Jul 15, 2017
490
N. IL
Or it's a flanged nut.
But if it's shanking out, probably a washer missing.
Orange1forme
Dec 1, 2018
394
57
Wa
The nut has a captured washer, still not tight.
I cannot find a breakdown or photo of this, even in the shop manual.
Went onto Messick's site and found this. Looks like just the nut/washer I have is all there is.
https://parts.kubotaofomaha.com/kubota-ball-link-32530-41520/
This link seems to show more threads than I have. I will go look at it and see.
wgator
Jul 28, 2018
482
147
NC
How is that other cable next to it, loose or snug?
Orange1forme
Dec 1, 2018
394
57
Wa
Snug.
It threads into the block, no nut on the back.
Threads on that are messed up!!! Most likely from using it without the nut on.
I threw on a couple washers for now. I'll get a new part and nut and replace it. Probably use some blue thread lock, too.
SRG
Jul 15, 2017
490
N. IL
Orange1forme
Dec 1, 2018
394
57
Wa
Well, this made no difference in the distance between the joystick and the steering wheel.
I still hit the wheel with the stick when I move the stick left. Hurts sometimes.
