B2601 will not start
Gsmittles
Mesick michigan
I have a 2021 B2601 and last Thursday it would not start. When I turned the key I just got a click. I bought a new battery for it and that didn't fix it. I bought a new starter and installed it and that didn't work. I checked the PTO lever and that is not the problem. I moved the pedal for forward and reverse back and forth and that did not work. The dealer that I bought it from changed hands and I can't get a traveling mechanic from to call me back. Any advice?
2,623
You can do some troubleshooting to isolate the problem instead of replacing parts.
First sit in the seat (as heavily as you can) and turn the key to the start position and hold it there. Then (one at a time) move around in the seat, move the HST pedal slowly forward and then towards reverse, then move the PTO lever to on and off with additional force on the off position. Test any other safety switches in a similar way (I don’t know what safety switches are on your tractor.)
If it tries to crank when moving a switch then that is the switch to work on with adjustment or replacement.
Do you feel comfortable with “directly jumping power to the starter” that bypasses all of the safety switches on the tractor to prove the starter and electrical circuit?
4,689
The parts cannon, is a tempting weapon.
I have succumb to its wiles on occasion.
I would suggest that since you heard a “click”, it is probably not a “safety switch”.
When my safety switchs act up (or are engaged) I get nothing…..no click, so sounds, no nothing except lights on the dash.
Start with the basics and don’t skip steps….I have never worked on a B tractor but here is a “off the top of my head” checklist.
1. Visual inspection for any “green” or broken connections.
1a. Check all grounds.
2. check all fuses, fusable links, or breakers with a meter.
3. Check the wiring with a meter.
4. load testing may be in order, because corroded wiring will pass a “continuity test”, but fail a “load test"
If you can’t find anything, then personally, I would jump that solenoid and see if it cranks. (use caution so that you don't get ‘run over')
Get a manual and it should be more specific on a “no start. no crank” problem.
I’m sure a “electrical guru” will be along shortly to point out my mistakes though…. ;) :ROFLMAO:
EDIT: Forgot to add my “funny" parts cannon meme.
Hugo Habicht
G1900
Jun 24, 2024
1,204
1,749
Ireland
Checking for voltage in the circuit instead of continuity with a meter would cover all poor contacts, weak battery etc..
First things I would check is all the fuses. So measure voltage behind the fuses when ignition is on. If one is blown do not simply replace but rather report back, there is a reason for a blown fuse which is typically a fault somewhere.
Is the click when you turn on ignition (stop/run solenoid) or when you turn the key to the crank position?
From what you describe the starter does not get any voltage. So check from starter key switch onwards. You did try pedal and PTO switch already but the seat switch is quite often the problem. You can short wire the switches for testing purposes.
You will need schematics or better, a work shop manual. You may find those on kubotabooks.com
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
419
475
NE Ohio
Likely culprit - A bad ground connection between battery and chassis. Corrosion or loose cable.
PorkBolt
B2601, 60" MMM, SSQA FEL, Kubota Ballast Box
Sep 22, 2015
39
Elburn, Illinois
Check the 5amp fuse (dash panel) . I have same model and for some reason if that blows my B2601 will not start. If found this out by swapping out controllers, safety switches, etc.....Last place I checked was fuse.....
