B2601 and BX2755HD problem solved
Have my new blower hooked up and having an issue with hose connections. Currently have the up and down for the blower hooked up to the white and yellow ports. Works perfectly. Therefore the chute rotator has to be hooked up to blue and red. Chute only rotates one way. Switched chute with up and down and it works perfectly. This leads me to believe the problem is now with the tractor. When I disconnected the fel everything was working. Anyone have a suggestion?
Update: to all who responded, Thank You. The issue was as suggested. I was not moving the control over far enough to the right. Chute works as designed.
