B2400
NoJacketRequired
May 25, 2016
432
68
Ottawa, Ontario
no hydrolics working? thinking pump is dead , how to clarify this?
Tip number one... Spend some time reading here so you can learn how your hydraulic system works. Don't expect folks to spoon-feed you - do some research and learning on your own, then come back with more specific questions.
5,205
1,889
what is a pump?
A device that moves something from one place to another
Your hydraulic (note the correct spelling) pump moves oil from the sump (transmission case) to other places via valves and such
thus, you have a suction side of the pump and a pressure side.
the most common cause of 'no hydraulics' is a suction side issue, be it a plugged filter, plugged suction screen, no fluid, air leaks between the sump and pump, etc etc
on kubota equipment hydraulic pump failure is very very rare; thus always eliminate the other possibilities first.
