B2400 noise and vibration in high range
moose517
B2400
Jan 6, 2024
12
Hey all just wondering if anyone has had any issues with a vibration and a gross kinda grinding noise when driving in high range. Kinda sounds like low oil issue.. recently had to replace a seal and some bearings behind bell housing area oil level on dipstick is right where it needs to be it calls for 12 liters only took like 8 to fill was drained where do u put/ check oil for the hst hydraulics are also kinda slow any ideas
2,659
What specifically did you replace? Was it making the noise BEFORE you replaced bearing? Or noise just now being heard?
moose517
B2400
Jan 6, 2024
12
Replaced seal on back of tranny cover the one that goes back to hydro unit and wasn't making noise or vibration before all we did was split tractor and remove cover on back of bell housing area replaced the bearings inside on the shafts and the seal on the output shaft now when driving in high range down driveway there is a decent vibration and a noise almost sounds like gears not meshing its a gross noise hard to explain
