B2320 not starting, no battery light on dash
Bradyboy2
Owego, NY
Hello folks, was using my bx2320 and got off tractor with it still running to move a log, tractor just shut off on its own. Now it won't start and I notice that the battery light is not illuminating on the dash panel either! Could sure use some help on what to look for! Thanks in advance!
2,670
Did you by chance hit the pto lever as you got off? How long DID it run after you got off - important to know this fact.
A bad ground usually does not stop an engine - but it will damn sure not make it start!
Sound like a safety switch that kicked in after you got off.
