I just recently purchased a 1992 B2150HSD with 950 hours on the working meter. She ain't pretty but she runs great, is what i would like to say about her! But I got no hydraulic function at all! No FEL, No 3pt, and no go in forward or reverse. The problem first reared its head last weekend, I started it up, moved it out of the barn, stopped for a second to reflect on the beauty of small farm livin, then no hydraulic function. Left it running while i read my manual, googled and such, then when i came back outside she worked just fine. My first though was the cold weather, it was around 30f when i started her, she warmed up and all was good. I used it for a couple hours to haul fire wood and grab logs with no problems what so ever. This weekend I planned on dragging some logs, started her up, let her warm for a bit, then got on and again no hydraulic. I let it warm for about an hour before giving up. I noticed the hydraulic fluid was milky and seemed rather thick so i changed it, the filter and cleaned the screen. the shaft from the motor to the hydro is spinning and i watched it stop as i depressed the clutch, then start again as released the clutch. I have no whines and everything seemed very strong when it worked. I have checked the linkage to the gear select and it is selecting. tried moving the 4wd selector to make sure it isn't bound. I hear a very slight hiss when i push the forward reverse pedal, I only hear it with the idle as low as it will go as it is so faint. I haven't seen any fluid leaks or level change in fluid. I sure would appreciate any help and thank you much in advance.
