Ref: B2150D 4wd manual gearbox - replacing transmission shaft centre joint / coupling - see photo - any advice welcome.
Thanks for reading this post. I have to replace the transmission shaft centre joint / coupling in the very near future and would appreciate any advice, tips and hints, documentation etc.
Although the coupling is visible (just) from underneath, there is not enough physical space to access it. It probably requires the machine to be “split” to be able to remove and replace the parts. I can’t find any documentation related to this repair and thought I would ask the question here before getting into it.
Looking at the machine it seems splitting it would be fairly straight forward. I have a good space to work in and a healthy selection of tools and experience.
Thanks in advance for any advice.
Attached is a diagram of the joint / coupling :
