B2150 industrial tires?
coxey2
b2150
Jun 28, 2011
17
ky
Hi, I have turf tire on my 2150 and want some industrial tires for the rear. I can't find any in west ky? Any ideas???
Kytim
Aug 14, 2009
848
Western Ky
what part of west ky you in? I'm in hopkins county between madisonville and hopkinsville.
DsBota
B8200, G1800
Apr 13, 2010
281
Milton, Ontario, Canada
I don't think you'll be able to find industrials to replace your rear turfs anywhere. I believe the B2150 ratio is the same as the B8200 and you'll need to change the fronts also. 12.4 x 16 rears and 23 x 10.50 x 12 on the fronts.
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
What size tires are currently on the rear of your machine, Once we know that then it may be possible to find an R-4 tire that has the same height and width characteristics as your current tires. If an R4 tire is not available for your rim size you may have to switch to a different rim size, The critical thing is getting a tire that has the same circumference so that you can use your existing front tires.
Replacing your rear tires with an exact height R4 tire is based upon the assumption that your B2150 is 4x4, If it is 4x2(rear wheel drive only) the tire height is not as critical.
You may not be able to find an R4 tire in your desired height but you may be able to find a light truck tire with an aggressive tread pattern that will wotk for you.
