B20 BH power steering fluid loss
robertcorzine
b20 front loader and 4foot box blade
Feb 5, 2015
southern mississippi
When tractor is cranked, all the hydro fluid runs out from bottom of steering unit. Its the unit worth rebuilding or is there other problems that need to looked at?
6,438
Sound like you've got a broken case, you'll have to tear into it to find out what broke.;)
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum from Northwest Alabama.
robertcorzine
Feb 5, 2015
Do anyone know if any other model tractors power steering Systems will work on a b20? The old one was full of water and had a crack on the bottom. I seen on the forums that that was a bad power steering system that let water get in through the steering shaft. I acquired distractor 2 weeks ago from the back of the Kubota dealer it has been parked out back for over a year it cranked up with so help to the battery and ran good for not running for a year .It started leaking when i used the front loader to check if the 4x4 worked i went and turned the wheels and it loss all power steering so i backed it back where it was parked and it started pouring hydraulic fluid out
6,438
You can get parts to repair it or you can buy the whole unit.
You could also try West Kentucky Tractor parts for a used unit.
http://wkytpstore.com/
Post some pictures of the damaged parts when you get them out.
robertcorzine
Feb 5, 2015
wolfman sorry i have it at the michine shop to see if they can rebuild it the bottom plug out and when i took apart the bearings hit the floor i try to get some pics tomorrow if he hasn't started rebuilding parts
