al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
So it's been awhile but bottom line,I learned a lot,and tractor is back together and working well. I bought another trany from a member here who was kind enough to ship it to me. It was out of a f2400, and the older style,and fit fine,just had to change one gear as it had a different tooth count. Another thing I learned is all the components attached to the outside of these two different hst are interchangeable,as well as the 4wd shaft. I chose to go with a different hst because the grooves were so deep in the plates I had to lap away most of the brass. I also lapped the plates fron replacement hst but they were in much better shape and required less lapping
