I recently purchased a Kubota B1750 and don't know a lot about tractors. This one only had 990 hours but I have come to find that it was NOT maintained. Currently have two issues and would welcome any advice. Main issue: Tractor ran great and had plenty of power for about first 5 hours I used it then next time I started it, it has lost power. Only runs up to about 2200 to 2400 rpms and bogs down easily. I have changed to fuel filter (which looked like it had never been changed before and was really clogged) but did not help the running issue. Any suggestions what I should try next?
Second issue. Hydraulics. Front loader after few minutes becomes slow and loses power. (same for rear lift). I have changed the fluid which was a mess and had some water in it. (changed it twice as I missed he two drains on the rear axle the first time) but again, not much if any difference. This issue was present even when tractor ran great. My model, not the hydrostatic, does not have a filter but I changed the screen. The front bucket is usable but no where what it should be. The rear lift will lift my tiller when first started but 5 minutes later won't lift it to clear the ground all the way. Again any suggestions would be helpful as I don't really know what I am doing.
