b1750 dead/no lights???
mtnsheep
14
Gainesville, GA,
I removed fenders and foot plate today to paint them and the frame, only disconnected R rear hazard light at fender connector. Put all back together, started tractor to run and noticed key would not turn tractor off , so pulled shut-off switch. Tried to restart and not light on dash at all, no hazards at all, nothing. Checked connections and fuses and all looked good. Can't figure out why it was running, but key would not turn off as well as why nothing after that. Any help is appreciated. I checked connections at hazard to make sure correct wire and no paint on it. If had mistakenly connected the wrong wire, would that do all this? Also, wouldn't the fused be blown? This just doesn't make sense. Thanks,
