B series front receiver hitch
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
Has anyone used this before? Looks good. It's a receiver hitch that mounts to the front of the B series tractors from Fabworks.
Didn't know if it would interfere with anything else. If anything it gives a good tow hook in the front if the tractor ever gets stuck.
http://www.fabworksoem.net/kubota_bsh.php
Funny I just ordered one for my BX it just shipped today. Not supposed to get in the way of loader and I am pretty sure it won't as long as hitch is not in.
asgard
B2301, 60 inch deck, 51inch blower
Oct 22, 2016
147
15
Ontario, Canada
I made my own for tehB series, I wanted it lower so I could attach the accessories I already had.
I have as well as a standard ball mount a drop unit for my utility trailer, a hook and a winch mount plate. I made an extension for the rear so they could be used there too.
I have 2 holes in the front one for short and long tubes and 2 on the rear for adjustment in and out.
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
That's an awesome setup!! You should fabricate more and sell them.
BotaTrac
Kubota B25D, Kubota L305DT, Kubota L2501D, Ford 681 Select-O-Speed
Mar 16, 2017
102
Hogwarts Academy
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Very nicely done!!
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,511
710
Richmond, Virginia
I have it on my BX. Fits great. Plenty of clearance with the FEL
They warn you that some hitches may have to be cut down to fit due to limited depth but none of the ones I have had to be cut.
Keegan
CNY
Yes, very strong:
Ok I think details on this setup are necessary! Did you put auxiliary hookups to make this system completely removable?
I want to do a similar setup when my bx2370 comes in, with an external battery jumper block. With a receiver hitch on front and back, a winch could be used in either direction.
