B-748B Snowcaster clutch shaft
Traylor
B7100
Jan 15, 2011
Hubbardsville NY
The splines have stripped out on the clutch shaft for my B-748B Snowcaster that I use with my B7100 tractor. My dealer cannot find the part number or any other information.
Can anyone help with information?
300zx
Dec 1, 2010
445
Forest, VA
Traylor, here is an earlier post talking about the availability of the shafts:
http://www.orangetractortalks.com/forums/showthread.php?t=3554&highlight=b748+clutch
As far as I know, they aren't available unless you can find some NOS or occasionally one is listed on ebay. Use the search feature, some people have adapted shafts to the front crank pulley using the 3 holes in the fan belt pulley behind the crankshaft splines (which is what I did).
Good Luck,
John
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Yep unfortunately unless you can find a machinist to repair that one or make a new one you're in trouble. You can hunt around for them but they're rare. After looking into using the front PTO shaft for a blower the conclusion I came to was that it would be easier to use the rear PTO whichever way I went. Whether that meant routing a belt up front from the rear PTO, getting a under shaft kit, or using a rear mount blower.
What killed the old one? Was there a Lovejoy coupling in the power train? They help damp vibrations and misalignment.
