b 7100 3 point hydraulic problem
bigbullhunter
b7100
Mar 19, 2011
santa fe NM
i recently bought a b 7100 tractor,the 3 point does not go up or down when the lever is lifted the last owner told me that it would work occasionally when it gets warm can anyone help with this
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Silly question but have you checked the oil level with the dipstick on the top of the box?
Dave
gktilton
B7500 with Loader and MMM. Woods M4 Bush Hog, Kuhn Rototiller, 3PT Snow Blower
May 5, 2010
234
Hooksett, NH
If this dipstick shows a good level, next step would be to chech the strainer to see if it is clogged. For this you need to drain the fluid and remove a bolt from the side of the transmission, that bolt goes through the suction line to the hydraulic pump, it is on the right side of the tractor and hidden by the tire, I always pop my tire off before trying to remove it. Also when you engage the lever in either direction do you hear any change in the noise from the engine area?
