This is a tractor forum, but what the heck.
Does the generator have brushes or does it use a capacitor?
Check the circuit breakers with a VOM. Gen not running of course.
Next ohm from neutral in a receptacle to its hot. Do this with gen off. Take the leads on the VOM, put one in the receptacle and the other in the same receptacle. You should measure 0.01 ohms. This will check from the receptacle thru the windings.
If the gen has brushes, carefully loosen the brush assy and take it off - don't let the springs behind the brushes fly out. Visually check the brushes and ring.
If capacitor, check the capacitor with a meter to see if it is working.
Report back with what you find, and we'll try from there.
By the way, don't flash it again.
