I have a B2650. I'm adding a monoblock valve that requires a tank return. New to hydraulics.
As I understand it, the tractor has two tank returns - one from the 3PT and one from the loader valve.
My plan is to add a manifold to the loader valve return and then plumb the loader valve and new valve T ports to the manifold. In addition, the manifold will provide extra return ports for future valve additions, like rear remotes.
I've included some pics of the proposed setup. It mounts using an existing hole, and the seat (in both positions) and control levers (for 4WD and 3PT lift) clear it, no problem.
My concern is plumbing the loader valve and new valve T ports to the manifold ABOVE the tank return. The factory setup uses a small length of hose from the loader valve DOWN to the tank return.
My understanding is that tank return lines run in the neighborhood of 50PSI, so I'm thinking that's still enough pressure to easily overcome the lift to the manifold, but since I'm new to this, I want to be certain before I start cutting stuff.
Would appreciate any other feedback, too.
Thanks!
Thanks!
