Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Hi guys, time to try and repay you all for the help i've received from you all to date.
On the basis of how hard and time consuming it can be to source original spec and parts number of older kubota kit, i thought i'd offer my help with a few bits.
I have an original spec sheet for the S-850 rotary tiller
Also have an original B6000 parts manual (100 pages worth) which has all the original parts numbers etc and also has the all the part number etc for both versions of the s-850 tiller.
there is an original operators manual inc all part number and fitting instructions and specs etc for the 619B backhoe.
also the same manual as above with all teh same details etc but for the KUB206 front loader
a full service manual for the B6000
finally the assembly,operation ,maintaince and spare parts list for the Backhoe models, 130 and 180.
KB180 backhoe spares manual etc. Contains spare parts numbers of all parts, schematics etc even modified part numbers and diagrams of the modified part for specific serial numbers of backhoes, a really handy to have book.
afew other spec sheets on b6000 kit also.
all the above have very good diagrams etc which i found a real help let alone finding that elusive part number.
most of above is for the B6000 but can also be found fitted on other kubota tractors aswell, the backhoes and loader are an example.
if you need any part numbers or parts drawing / schematics or other info for the above , drop me a line and i help you out by email or fax.
thanks
rob
thanks
rob
