Anyone have a part number for
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
the hydraulic filter on an Kubota (Kioti)L2202? I measured it, thread is M20 x 1.5, Gasket ID is 2"/51MM, Gasket OD is 2-7/16"/62MM, Filter OD is 3-1/8"/80MM. Height is 4-9/16"/111MM, or 5-7/16"/138 MM, depending if you measure to the bottom of the 24MM drive nut, or to its top. It is a full flow filter, paper media. It mounts on the right rear of the motor driven pump, gasket surface down. I looked for a suction screen, tractor has the mounting boss for it in the casting, but no boles are drilled. Hydraulics are slow, but seem strong, so I am hoping it's just a clogged oil filter. Thanks for any help!
