Any need to bleed air after transmisson oil change
man00
197
12
okla
About to do the above and wondering if there any need to bleed air? This is on a B2320DT Gear with FEL I couldn't find anything in the manual about it.
2,551
Being that it is a stick shift - there is no pressurized system. On that model I am not sure if the tranny and hydraulics use the same sump - gonna bet not, either way - the air will bleed itself out in the hydraulic end.
5,203
1,888
The hydrualic oil and transmission oil are one in the same on that tractor (and the HST's as well). It all resides in the transmission case/sump. There is no bleeding procedure. Refill with proper amount of oil and you're done.
6,340
Most if not all Kubota's use the transmission, rear diff, and axle housing as the hydraulic sump. ;)
