Antifreeze
L2501dt
27
Connecticut
L2501. Coolant reservoir is just below low level. What is recommended to top off. Not looking for the scientific make up of what coolant is, just what people put in their kubota tractor
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
It most likely is regular ethelene glycol. Same that has been used for decades.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
What color is the antifreeze in the engine? It's not so important what antifreeze you use but they aren't all interchangeable. For example you shouldn't add green antifreeze to a system that has orange antifreeze in it. If the antifreeze has been used for a long time you might go ahead and change it. Antifreeze has additives in it to prevent rust and they wear out. The tractor should use plain old ethelene glycol antifreeze commonly available for cars.
L2501dt
27
Connecticut
has green in it. Just need to top off only has 133 hrs. Will change it eventually
Jim L.
852
155
O'Reilly brand name ethylene glycol is colored green.
AutoZone has a green color ethylene glycol under its brand name.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
609
526
Indiana
Likely 50% ethylene glycol / 50% distilled water at whatever volume needed. Higher than 50/50 can degrade the heat transfer out of the engine and radiator. Lower and you are at higher risk for freeze up in winter or boil over in summer.
You can get pre-mixed at O'Reilly and Autozone if you don't want to mix it yourself.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
407
123
Glendale, Rhode Island
Sorry to disillusion anyone, but the color of antifreeze does not always relate to it's properties. For instance, the company that manufactures Kubota anti-freeze describes it as being a clear liquid, with a dye added to make it appear green. What if they decided to make it appear blue? I would suggest relying on the specs and not the color.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
My L2501 manual calls for ethylene glycol anti freeze. If you don't buy pre mixed (I don't) mis 50/50 with distilled water. Prestone it "the" name in antifreeze. Any other brand will work just as well. The big thing to look for is ethylene glycol or compatible with ethylene glycol.
whitetiger
Nov 20, 2011
2,910
1,374
Kansas City, KS
4,384
Kubota specifies extended life ethylene glycol antifreeze for use in their engines.
That leaves out conventional green (IAT formulation) antifreeze. IAT is old technology and is relatively hard to find but still sold under house brand names like Autozone and Orielly.
Just about any brand of extended life (OAT/HOAT formulation) coolant would be acceptable. This is by far the most common type on the shelves today and can he found in many different colors including green.
The key is the antifreeze should have the words "ethylene glycol" and "extended life" or "long life" on the label. A gallon of Peak, Zerex or Prestone extended life concentrate will run you around $20. A gallon of "genuine Kubota" extended life concentrate is $30.
