Advice for an upper arm Hydraulic pump on the PTO
FJK
Kubota MX5400
Aug 16, 2022
Central California
Hi all and Merry Christmas,
Looking for advice on what brand to get or stay away from regarding a hydraulic pump on the upper arm of a PTO.
I have a Kubota MX5400 that this pump would go on.
When I bought the tractor, I had the seller install the hydraulic system needed for the bucket ( 4&1 bucket) and was told because I already have this on the tractor currently, I'll i need is the pump for the upper arm and a couple of hydraulic lines and fitting to have the pump functional.
Any input, positive or negative with this project will be appreciative! Or better yet, if you have a pump on your PTO and if you are happy with it.
All the best to all in the New Year
6,619
Ok I think we are having a real issue with terminology.
PTO (Power Take Off) is the shaft that spins on the back of the tractor.
You do not need another pump, the tractor already has a full working Hydraulic pump system.
I think what your calling a pump is the hydraulic cylinder???
I'm betting what you need is a third function valve.
This valve would control a front loader attach implement like a 4 in 1 or a grapple.
Summit, Land pride, (Kubota) and WR long all have kits to do that.
