Adding rear hydraulic hookup to L3940
Eric Wooldridge
Kubota 3940, kubota 8540, lots of farmall cultivating tractors
Feb 3, 2023
TN
Hi all, I Am a produce grower in mid TN and purchased a 3940 last year to help get more done.
I need to install hydraulic hookups in the rear for our transplanter and have some questions about how to do this. I know there are kits you can buy but I’m trying to figure out if the tractor is already equip with some of what I need.
Can anyone give me some guidance on how to do this?
Easiest to just buy a kit?
Can I use the joystick to engage the rear hydraulics once installed? No loader is on the tractor.
Thanks for any help,
Eric
Bells Bend Farms
4,328
Eric
Bells Bend Farms
I dont see any levers for factory rear remotes and those kits are probably NLA.
Adding a commodity valve for rear remotes is straightforward and not particularly expensive. You could use the loader ports for a rear attachment but I think you will find it is a PITA
6,088
Why is it a pain?
With the loader valve already installed he has 2 Hydraulic outlets that just need hoses hooked to them.
Easy as that?
4,328
Why is it a pain?
Easy as that?
Its an opinion.
Hoses to the rear are ugly and cumbersome and the valve is designed for loader operations not rear implements.
Put a set of rear remotes on it and Its an improvement not a kludge.
Just my $.02
6,088
If he was using a loader I'd 100% agree.
While I don't like hoses either, it would by far be the cheapest and quickest solution!
That loader valve looks to be pretty convenient for this task.
Set of jumpers to a rear mounted block and he's good to go.
kubotafreak
Sep 20, 2018
1,044
390
Arkansas, US
Eric,
Some times they have the factory diversion kit on ebay for the 40 series. I see them from time to time. (L8349)
kubotafreak
Sep 20, 2018
1,044
390
Arkansas, US
Is that the kit that replaces the front loader pipes with hoses and outlets in the rear?. If so easy to roll your own.
True... good alternative if you have the capability, and time
6,088
Eric Wooldridge
Feb 3, 2023
TN
Thanks for all the suggestions guys!
I can picture what needs to happen here but am unable to find the right hose looking online. Not trying to be lazy but can anyone send a list of what I need or part # for the extension hoses that will run to the back or is it not that simple?
Is the "rear mounted block" just a bracket that holds the hoses or is that the quick connect thing in the rear?
Thanks for educating me!
4,328
You just need two roughly 10' long lengths of hydraulic hose with 3/8" make pipe ends and four female quick couplers.
The OEM couplers for the front are 3/8" Faster HNV (ISO 7241-B) and they screw right onto the hoses. Then plug them into the male tips on your tractor. Here is a generic equivalent for the Faster couplers.
https://summit-hydraulics.com/product/3-8-npt-iso-7241-b-quick-disconnect-hydraulic-coupler-set/
The ones for the rear would be any 1/2" ISO 5675 agricultural coupler which you can get at any local tractor supply. You will need two 3/8 female NPT to 1/2 male NPT adapters to screw them onto the hoses. You can get them from the same source.
If you are going quick and dirty just plug them into the front, run them along the fender, and zip tie them to the ROPS
6,088
For clarity: This kit that KubotaFreak pointed at, replaces the forward lines to be rearward lines with quick disconnects.
Eric Wooldridge
Feb 3, 2023
TN
Thank you. Quick and dirty is the way I've got to go for the coming season...just too many other projects to finish by March.
I want to make sure I'm getting this right before I order:
Here is the main hose, 8' 3/8 male ends (x2): https://www.amazon.com/gp/product/B09WRT92LF/ref=ox_sc_act_title_2?smid=A1YZ3POA56ITHS&psc=1
Front quick connect to existing tractor male part ( I need 2 ): https://www.amazon.com/gp/product/B07N1VJ61C/ref=ox_sc_act_title_1?smid=A1VH34FQCDTBWO&psc=1
For the back end,
This adapter x2: https://www.amazon.com/gp/product/B0877YFWM8/ref=ox_sc_act_title_3?smid=A2GWB408K7VADK&psc=1
Then adapter to this quick connect (x2): https://www.amazon.com/cart/smart-wagon?newItems=57ca65c3-ccb9-43a8-bc72-786246ef2629,2
Is that right?
Thanks,
Eric
4,328
For the back end,
Is that right?
Thanks,
Eric
Link to rear couplers does not seem to work but otherwise yes.
4,759
Before you order, consider checking the prices at https://www.discounthydraulichose.com/. I have ordered from them and they are fast and economical with good quality. If you are not certain as to exactly what you need, you can call and speak to a live person that actually understands and knows what to recommend.
4,328
If I were to do it again, I would run the hoses straight to the hydraulic top and side link with NO disconnects. Saves money since I have never had a reason to disconnect either the top or side link!!!!
Except of course he is not using them for top or side links.......
Eric Wooldridge
Feb 3, 2023
TN
I've got the parts and am getting the hoses put together. For the valve block (4) on the tractor that I'm hooking these to, which 2 do I hook to for the joystick to operate it?
Thanks,
Eric
4,328
Thanks,
Eric
Dont know the specifics of that valve but the two that operate the loader boom - they will be on the top left side of the valve.
