Adding electric valve to sprayer
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
313
79
Bagley, MN, United States
I am looking to get by on the cheap - found these for sale on Amazon. I am planning to add this to my 31 gallon tank sprayer boom to remotely turn the boom spray on and off. Noticed that Amazon valve had 3/8" 'BSP' threads so found another on Ebay.
https://www.amazon.com/dp/B01FU3Y4VW/_encoding=UTF8?coliid=ICQ9OJF7Z9HKT&colid=HGUDMMP8HN3S
https://www.amazon.com/dp/B005DSTC6W/_encoding=UTF8?coliid=I37Q0I6EMY766F&colid=HGUDMMP8HN3S
https://www.ebay.com/itm/U-S-Solid-3-8-12V-Brass-Electric-Solenoid-Valve-DC-Air-Water-Normally-Closed/272024240641?epid=1904044479&hash=item3f55e88201:g:-4YAAOSwFNZWuglW
rjcorazza
Mar 9, 2016
778
24
Hyattstown, MD
You specifically ask about electric valves, but if you're using and electric pump sprayer you can wirelessly control power to the pump with a plug n play switch from Fimco.
243ackley
90
Birmingham Alabama
What tractor do you have (wondering about your electrical panel). Also, how tight is the cab? I don't know what it takes to get a wire into the cab...
What size hose connections do you have now? Are you replacing something like this?
http://www.agrisupply.com/manual-valve-gpm-psi/p/72483/
That valve is very similar to the one I have now. I think my unit uses 3/4 inch pipe.
Tractor is a m7060. I don't take delivery until Friday. The owner's manual is showing a spot for a plug in the cab. I guess I can buy the right plug from Kubota and wire the controller to the plug and I will be in business.
