Hi all,
Made a clumsy move when trying to fit a new clutch assembly to my kubota B1500 tractor. As a result the unit fell into a bowl containing engine oil soaking the whole assembly. Within seconds I retrieved the unit and quickly wiped it down, removing all the oil I could see. The new clutch disc I sprayed with brake cleaner and wiped any residue. I then used an air compressor to blow away any hidden residue and placed it near a radiator, to try and dry it throughly. I am worried if the oil in that short period would be absorbed and render the clutch disc unuseable. Your views would be welcome and any views as to whether brake cleaner was the right agent to use. I am in the learning mode.
