So I finally got around to installing a small auxillary fuse block to handle the winch, lights and so on. Powered a relay from the main accessories terminal so the new panel is only on when switched. Hooked up winch - works as it should. The problem? There are 4 little lights on the new fuse panel that should light up when power is on. They are not, but WILL light if I touch a terminal to a ground source.
The relay ground checks out fine (ran a new lead to the frame). The screws on the fuseblock itself have battery ground continuity. So how come no fuse lights?
