95' b20 tlb
Pine Cone
B20 & B6000
Jun 15, 2012
Georgian Bay, ON Canada
Greetings,
I have what appears to be a leaky transmission. Hydraulic fluid comes out directly under tractor between operators feet. It only seems leak when the tractor is moving and stops leaking when machine is off?
Having a hard time locating where exactly its coming from?
Can any one help
Thanks a ton
Thomas Hynes
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
You have several hydraulic lines that join the transmission in that area. They are all mounted with "banjo" bolts. Sounds like it may be as simple as a loose bolt. Have you checked them all to see if they're tight?
