Hello to all and thanks for any help with my problem. I need to remove the swing cylinder from a 4530B backhoe in order to replace the seals. The chrome rod that passes through the cylinder is bolted to the frame on both right and left side. The right side has a flat spot at the end of the chrome rod that allows a wrench to stop the rotation of the rod to undo the bolt. So far good as I got the bolt loose OK.
Problem is the left bolt...there is no flat spot on the chrome rod to hold with a wrench. I thought the rod was one piece and put the wrench on the other side of the rod which has the flat spot, but then the left part of the rod turns even though the right side does not. Tried using a vice grip not on the chrome but there is a small part at the end not chromed. This did not work since it slipped. Since the rods turn independently seems to mean either the rod is in two pieces by design or it is sheared/broken. From what I see in the parts diagram in the manual looks like one rod all the way through but I could be wrong.
Anyway this is a confusing thing to me and wonder if anyone has done this and can help with removing that bolt. Thanks again for any info.
