4 wheel drive seize?
5,248
1,925
Have run into this before on a B7500. Similar tractor as a B2400. Found front hub bearing failed, dropped bearing balls down into the bevel gear, locked it solid.
rbargeron
Jul 6, 2015
1,171
238
western ma
Will it move in 2wd? Lift the front and try to rotate a wheel by hand. I one turns, problem is in the other. If nothing will move its in the pinion/differential/driveshaft blocking both sides. See what difference disengaging fwd makes.
