Hi
I hit a stump and ripped off my 2 hydraulic lines feeding the 3rd function valve coming off the power beyond. After replacing the lines the grapple claw didn’t work properly. I swapped the lines and it worked but was overheating. I swapped the lines back and the claw function was reverse of normal, bleeding down quickly, and still overheating. I swapped the lines back yet again and the claw functions properly yet the claw still bleeds down and hydraulic unit is super hot. I can only assume I have the lines hooked up correctly at this point. Fluid level is just a little over full. What would be causing this over heating issue? Thank you for any help!
