I have recently bought a L2650 and the 3 point hitch wouldn't go up. In a earlier post I had asked if the control valve for the loader might be the cause. After checking it out, it turned out to be the arm under the cover is broken. I've disassembled it and found all of the pieces except the roll pin that holds the push pin to the arm. I'm still looking for that. Now here is my question for help, I did not mark the main shaft to arm location before taking it apart. I knew I had to before I started, but had a brain fart and forgot. How do I clock these two when reassembly time comes? Any help would be appreciated.
Thanks, AC
Thanks, AC
