3 point sickle bar for L3301
Deaner70
L3301, LA525 loader with QA, LAnd Pride RCR1860 hog
Aug 26, 2015
53
Shreve, OH
Anyone use one on the 3301? Currious how the stability is? Need someting to mow about a 1/4 mile of ditch. Looking for a used Belt driven NH or Ford to use.
Thanks
Larry
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I have a b2910, and converted an old IH 7 footer to 3 point. Well, actually 2 point, it has a tail wheel. Back tires are partially loaded, less than half full. I have never felt unstable using it, even when using the hydraulics to bounce the wad of grass off the bar. I would think your L would work even better, bigger, wider, heavier.
Sent from my LGMS330 using Tapatalk
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
439
Red Springs, NC
I have a Case IH 1300. It mounts only to the 3pt hitch no axle brackets and it will mow any place from straight up to straight down. it is belt driven. Made in 1995 and Webb sickle has all the parts for it. I run it on a L3700SU or the 8n Ford so it would do good on the L3301.
BAP
Dec 31, 2012
2,857
949
3 point hitch sickle bar mowers make a great ditch mower as long is there isn't any brush to mow. The bar is light so it doesn't put a lot of leverage on the tractor making it tippy. A good sharp cutter bar will cut grass, weeds and young new brush very good.
