3 Point Position Control Lever Hard to Move
huntersprings
M4800
Dec 7, 2014
53
Taft, TN USA
I changed hydraulic fluid on my 4800 about a month ago. Since that time the position control lever is very "stiff" to move and my 3 point lift will barely get my cutter off the ground. Fluid level looks ok on the measuring stick. Yesterday while cutting some brush I looked back and the cutter was lifted to full height? I dropped the position control lever and the cutter didn't fall back down right away. I haven't ever adjusted the float control knob till then and the cutter did drop down. Any suggestions?
8,756
Does that model have draft control?
huntersprings
M4800
Dec 7, 2014
53
Taft, TN USA
No draft control lever. It only has the position lever. M4800SU model. The power steering and remote work fine. I have a parts manual with diagrams but don't understand how to make adjustments to the feedback linkage, if that is the problem. Any advise would be appreciated.
