Hi All,
First time poster. Unable to find solution in past threads.
My B8200D has a 3-point lift issue. In the last months it's having a problem lifting. I've removed the pump and check specs which are OK. When I return the pump to the machine the lift works for a while and then gets tired and won't lift. I again removed the pump and again found it up to specs. When I put it back the lift worked again but as I was working got more and more tired.
I am in a bit of a jam here, as I use the machine to plow my long driveway and can't get in or out otherwise.
Thanks in advance for you help : )
Dennis
Dennis
