After breaking another one of the Kubota stabilizer links this spring, I decided to build a set of telescoping stabilizers that would be stronger. I had a little over two feet of material left from a telescoping drive shaft I bought to make a shaft for the snow blower on my 430 John Deere. The bar is 3/4" by 5/8" and slides into the tube with minimum of play. I cut bars and tubes a foot long and laid out a series of holes on each one, 3/4" spacing on the tubes and 5/8" spacing on the bars. That was a lot of drilling, but my 3/8" cobalt bit was drilling just as well at the end as in the beginning. I made clevises for the ends out of 1/4" X 1" bar stock and welded them to the ends of the parts. I bead blasted the parts and gave them a coat of self-etching primer and a couple of coats of Kubota Gray. I used a couple of clevis pins to set the lengths that can be adjusted in 1/8" increments.
I 'll see how they hold up when pulling the utility trailer and box blade.
