3 point hitch lever will not move
CHF
M5660, B2320
Mar 27, 2020
St Johns, Florida
Good morning, I have a B2320 with a belly mower. My problem is that the 3 point hitch lever is stuck. When I leave the tractor over night, it unsticks but once I turn it on it will usually not move out of neutral. I have tried adjusting the knob under the front of the seat that controls rate of descent with no avail. The level of hydraulic fluid may have been low so I added some (it is very hard for me to read the level on the dipstick.
Thank you for your ideas.
Charlie
torch
Jun 10, 2016
2,791
1,013
Muskoka, Ont.
It sounds like the hydraulic pressure is making it bind. Perhaps a damaged o-ring on the spool valve is catching on a port?
9,252
Feedback linkage might be binding causing it to stick?
CHF
M5660, B2320
Mar 27, 2020
St Johns, Florida
Thanks for the follow-up. The lever linkage appears to be fine. How would one access the spool valve to check for a damaged O ring? I only have the 3 point hitch and belly mower. I do not have a front end loader.
Thanks, Charlie
