Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Here's a question, probably for SD Vic, but someone else might have experienced it.
On my M4500, whenever I use the hyd remotes the lower 3 point links "jump" a little. Is this a typical thing with the older M series tractors, or do I need to go clear through the adjustment procedure in the workshop manual? This isn't really one of the problem symptoms described in the troubleshooting section.
