25-30hp Bx models
WolverineMarine
LX2610 with BH77 backhoe
Aug 16, 2016
21
NW Ohio
A 25-30hp bx series is potentially in my future if they have 1-2 remote rear hydraulic ports available with the pto and 3 point hitch. Are those all available on one of these tractors?
Fortes fortuna e uvda. Fortune favors the brave
kupitz
BX2660 with LA243 FEL and Front mount BX2750 snowblower/2763A heated Curtis cab.
Mar 28, 2016
130
New Providence, PA
Rear PTO and 3 point hitch are standard, the rear hydraulics are an option.
2,675
BX series will not get that high......true there is a 26hp bx, but if you need more, you will have to go with the "B" or "L" series.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I've had several different tractors. HP has ranged from a low of 18 to 30. My 18 hp BX seems to do all that is needed. I had a larger blue one with only 18 HP. Had no trouble doing significantly more work effort with that larger tractor and no problem of not enough power. I'd forget the idea of lots of power for the size of the BX. You probably don't need it.
WolverineMarine
Aug 16, 2016
21
NW Ohio
I'll be plowing snow in the neighborhood and using a pto mounted rear snow blower in addition to some light land clearing at our home in Minnesota and our land in Wisconsin. The reason why I asked about the rear hydraulics is to be able to use other implements for food plot prep and possibly a 3 point mounted log splitter.
WolverineMarine
Aug 16, 2016
21
NW Ohio
Anything below a compact utility tractor won't suit our needs
WolverineMarine
Aug 16, 2016
21
NW Ohio
I guess I'll just be going into a B series. It's more what we'll be needing.
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
Just note,, the bx has very limited ground clearance, 5 to 6 inches. Working in the woods is it's biggest challenge.
jpz has a good point, I use my tractor as a mini skidder. It is a B2620 and has about double the clearance. I also have a stand alone splitter and I can bucket the wood to the splitter, kinda like bench work. Cant do that with a 3 pt splitter
WolverineMarine
Aug 16, 2016
21
NW Ohio
Wolverine
Here are a couple of pictures. Note clearance on b2620
That's a great looking setup! I really like your grapple on the bucket and is that like an 8" inch steel pipe probably filled with concrete for counterweight on your 3 point?
pendoreille
Jan 2, 2015
476
Newport, WA
10 inch well casing x 50 inches plus concrete. about 400 lbs. tucks in tight and low for getting about the woods.
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
If you aren't in a big hurry the new BX line will be out this fall is what I hear from my dealer. What is the land like you will be working? I have a BX25 and with the hills it is perfect, the B series was too big for most of my needs.
1970cs
1,124
Grand Ledge
Actually, the new BX series will be available for order at the dealer meeting in early October so best case would 60 days after that?????
Pat
