245DT 3ph repair
Humphry
245DT 1980 w/bucket and3ph
Aug 14, 2015
New Sharon, Maine
My old tractor has no function of the 3ph. It worked sometimes when I first bought it. I believe I've read about a warmup time required for the older ones. Can I fix it? How far will I have to tear it down? I believe it's a 1980 model.
11,502
You really shouldn't have to wait for the three point to work, if you do there is a problem.
I'll email you a link where to download the WSM, that will give you some insight and some trouble shooting/repair help. ;)
WPA245
1979 L245DT;model1200loader/K650backhoe
Aug 7, 2015
14
Greensburg, PA
You shouldn't have to wait for your 3pt to work.
The manual does however say you should wait for the hydro oil to warm up before using any hydraulic attachments. If not warmed up you risk damaging the system.
I just partly disassembled my L245DT 3pt control cylinder.
I replaced the smaller of the two big o-rings on the cylinder cover which if leaking internally will disable your 3pt. I also replaced the control screw which was seized also disabling the 3pt hitch.
Don't snap that screw it's $54. It's the one between your legs under the seat with the knob.
Kubota's corporate site has all the system/parts breakdown for your tractor.
There's not a that can go wrong so you should be able to trouble shoot it.
