2019 B2650 hydrostatic drive randomly stalls when operating foot control.
warwagon
Ashville,ohio
Good morning, Im new to Kubota and new to hydro static transmission I bought a used 2650 with 330 miles last fall and have had intermittent stalling issues when operating foot hydro controls. I had a local farm mechanic adjust switch located under floor board associated with switch and tractor was running as it should until yesterday. Any help would be appreciated.
7,361
Your tractor hasx330 hours not miles on the clock.
Please provide a more complete description of the problem.
3,161
More than likely it is the same switch acting up. Please describe what you mean by “stalls”. How does it die (stall)? Is it like it had the key turned off (quickly), or is it like you applied too much load to the engine (slowly)?
Could be the cold effecting the pedal movement or the seat movement that effects those safety switches.
warwagon
Ashville,ohio
warwagon
Ashville,ohio
330 Hours is correct, Starts right up after each time it shuts down. Will be running normal at various speeds and cuts off no sputtering just dies. I touch nothing other than releasing foot control turn key and fires back up everytime. Switch at hydro pedals is pushed in at neutral and out at forward and reverse.
whitetiger
Nov 20, 2011
3,790
2,193
Kansas City, KS
Your HST pedal neutral safety switch is failing; replace it. It's not an uncommon complaint.
