2009 RTV1100 Transmission
thart1974
M7040FC, RTV1100, Mahindra 4510, JD 459, New Holland BC5070 Hayliner
Oct 14, 2024
Indiana
Is it possible to install a transmission, rear diff, transaxle, and hydraulics from a newer RTV X1100CW, more or less swap out everything from the flywheel back on an older RTV 1100.
whitetiger
Nov 20, 2011
3,726
2,148
Kansas City, KS
Not without a huge amount of fabrication.
thart1974
Oct 14, 2024
Indiana
I take it as no. Would the same year model, RTV1140 work on the RTV1100?
whitetiger
Nov 20, 2011
3,726
2,148
Kansas City, KS
The RTV1140 engine & transaxle probably could be put in an RTV1100 if you had the complete RTV1140 as a donor. There is no way to be sure, as the engine, trans-axle, and rear axle assembly are different part numbers.
I have not tried to swap them and haven't heard of anyone doing it. They are basically the same units, other than the frame length. The different part numbers are probably minor specs or differences.
thart1974
Oct 14, 2024
Indiana
Thanks for your responses. I did look up and notice they had different part numbers. I found a complete transaxle from a 1140 and I would get a 1 year parts and labor warranty, but it is several states away, so I can't take measurements and see what the differences are.
