13.6-16 (???)
jasons
27
Hallsville, MO
The rear turf tires on my Kubota L235DT show "13.6-16".
Will other sizes fit my Kubota wheel? This doesn't seem like a popular size at all...
Any suggestions are appreciated.
-Jason
al b
l345dt, l48, l2550dt
Feb 15, 2012
46
Ct
You need to keep the same tire ratio front to back or you will break something when you go into 4x4.
Bumble
L235
Aug 6, 2012
Prescott, Ontario
I feel your pain, I have an L235 and just repalced the front tires with industrial tires. But now try to find anythig more aggresive than diamond tread.
I think you ( and I ) will have to change rear rims if you want industrial or ag tires. Just be sure to keep the same tire diameter, as stated above. The 13.6x16 have a 38.1" diameter.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
If your tractor is 4 wheel drive you have to change rears and fronts both and have to buy different sized wheels for the front. Firestone makes the Turf & Field and Carlisle ( MUCH cheaper $$ ) make the Turf Pro in 13.6-16 so it shouldn't be a problem getting them.
I'm guessing you have 24x850-14's on the front and if so you'd be dropping down to a 12.4-16 on the rear and 23x850-12 on the front. Much cheaper in the long run to stick with what you've got unless you find a good deal on a set of new take off's where someone switched over to the R4 industrial lugs in place of the turf design.
Al
