110v AC motor/appliance start up monitor
2manybikes
19 L3560 HST with cab.
Aug 2, 2021
62
32
SW Va.
I have a sump pump that may be running more than I thought it was. I have a meter that reads wattage, voltage, power frequency, calculates costs excreta, but does not tell me how many times the device has turned on and off. That's actually all I really need but may have to purchase something more complicated to answer my question. I do not have wi-fi available at this location. I have done some searches but most of what I could find were for commercial applications and were cost prohibitive.
torch
Jun 10, 2016
2,745
965
Muskoka, Ont.
You need a cycle counter? Or would an hour meter be more appropriate?
2manybikes
Aug 2, 2021
62
32
SW Va.
I'm on the outer limits of my electrical knowledge! I basically need to know how many times the pump has operated in a given period. Say 24 hours or so. If the device cant break it down to time periods, then I'll just have to check it every day for a while.
MINICUP28
B7610, KX-018, RTV-500, JD X758
Feb 21, 2019
101
49
COBLESKILL, NY
I use these temp sensors to track how often the water softener runs (~every 10-14 days) and how often the boiler runs to heat hot water. I attach the sensor to the water drain on the softener and the exhaust pipe on the boiler. I collect the data on Ambient's ws-3000.
I take the micro SD card out to download the data.
For a sump pump, the motor case may not change temp fast enough if it is short cycling. You could try the temp of the discharge stream or pipe.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
280
283
Amsterdam, NY
Hourly, daily, monthly.
Something like this. $62
You're looking for a current transformer that can store data for export via a card for analysis in Excel or such. Many do not do this, you'll have to look around and the cost may go up to do so.
8,764
Hugo Habicht
G1900
Jun 24, 2024
607
800
Ireland
Do you just need the count or do you need detailed timing information like when it switched on and when it switched off? And do you need this data remotely accessible (GSM, Internet connection)?
Dustball
2016 B2650HSDC
Sep 15, 2023
418
274
Hudson, WI
Does the sump pump discharge to daylight and do you have a trail camera?
Put a mini paddle wheel in the discharge path and focus the trail camera on the paddle wheel.
2manybikes
Aug 2, 2021
62
32
SW Va.
Thanks to everyone for a lot of different ideas! I have learned a great deal about a lot of devices I had no clue even existed. I have an idea now, and have already ordered a few parts to construct it. I will report back when I get it built and tested. Thank you to everyone who responded.
