A few weeks ago I noticed the bucket cylinder rod seal was leaking, do I looked up the seal kit number, 75582-64600, and ordered it from Messicks.
I also got an OTC 7463 gland nut wrench off Amazon and it fit the end cap on the cylinder just fine.
So, I decided to pull it apart today and get it fixed. I raised the bucket up and rolled it all the way back, pulled the extend hose off and plugged the hose and cylinder port, then pulled the valve lever out away from the tractor into the float position to let the bucket roll all the way back out. I pulled the pin out of the end and pulled the ram the rest of the way out and pulled the retract line off and plugged the line and the cylinder port. I used the glad wrench and loosened the end cap a couple of turns, then took the pin out of the other end. I took it to the bench and unscrewed the end cap and pulled the ram and piston out. Using the plugs and caps on the fittings and lines I only lost a few ounces of hydraulic oil.
It looks like the seal kit is not the right one As you can see in the picture, the piston has a wide plastic ring and a square seal ring, neither of which are in the seal kit.
In the parts manual there is a serial number break at 25520 as to which seal kit applies, and my LA-211 serial number is 34284. So according to that the 75582-64600 kit is correct. I looked at the picture of the seal kit for the lower serial number loaders, and I don't see a large ring in that kit either.
I guess I'll give Messick's a call on Monday and see what they can figure out.
