I know we are way off topic, but I had a similar experience. I bought my Z in 1997 and 3 months later hit a deer! I took the opportunity to have our best body shop fix the right front and repaint the whole car. It came out of Washington, DC, had sat out and had acid rain spots. It came out great and has been garaged since.
I said in my last post almost a month ago that I had one bad injector. It took me two weeks, on and off, to get the intake plenum and all of the turbo piping off of the engine. It was a bear! When I would get frustrated with it, I quit and went on to something else. All of the injector connectors were covered with green corrosion. When I finally got down to where I could clean the injector side connectors so I could do a good resistance test, one was open (the bad one), three measured 0.25 ohms and the last two measured in spec at 12.7 ohms. So, I just ordered 6 new injectors yesterday. Based on the info on the Z forum I follow, it is a very common problem. I am cutting all of the wiring harness side injector connectors off and replacing them. I am friends with the local Nissan Parts manager. He sold me some butt connectors they use for similar repairs. It is clear heat shrink with a solder ring in the middle. You slide it over one wire, push the two bare wires together intertwining the wires, slide the butt connector back over the bare wires and use a heat gun to melt the solder and shrink the shrink wrap. I haven't tried it yet, but it looks like a great way to join wires.
Sorry you had to sell your Z. I have to admit, the last time I got mine inspected, I told the guy at the garage I had only driven the car 1200 miles over the last year and would rather have a Kubota. He laughed, but at 64 it is getting harder to get down in and out of the car and climbing up on the Kubota is more fun! That was when I started look for my B7100.
Here are some pictures:
https://picasaweb.google.com/110263893958737890068/1992300ZXTwinTurbo?authkey=Gv1sRgCI7e-Y2-7cOm0wE
