http://www.orangetractortalks.com/forums/showthread.php?t=36486If I were nearer to NC, I would be interested in several parts you are offering. (seat,mower-deck, PTO belt-tensioner components...etc)
May I ask..... what led to breaking the HST PTO shaft?
I am asking because I do hours of pulling with my G4200 (same tractor, different engine) With the AG tires on my tractor, this loads the HST pretty heavily.
Is there some 'weak spot' I should be looking out for?
Why bother? Either upgrade the whole deck or leave it alone. The deck gearbox is one of the most expensive parts on the whole machine, so why waste time and money retrofitting itCan someone help a newbie ? All i can do right now is find someones post about G4200 and reply to their thread. How do i search, where do i search, what do i click on. Totally lost. I'm trying to find out if i can use a gear-box from a G4200 (Gear) with a 44" deck, onto a 40" deck. The 40" deck came without a gear box. So i want to use the gear-box from the 44" in deck on the 40" deck. There may be a difference in the blades. I think the 44" inch blades have 3 mounting holes (1 large & 2 small), and the 40" blades only have 1 hole in the blade. I ordered a new blade for the smaller deck, went back and looked and only see 1 hole in the shorter (new) blade. If the gear-box has a 3 hole blade on it, what do i do ?
