advise on bush hog
waynemichael
b2601
Sep 13, 2017
winchester
Just purchased a b2601 2017 26hp . I need to bush hog . I have 14 acres of mostly flat land . Any suggestions would be appreciated . Mike
2,595
Size or brand?
5' er will fit that machine well - brand, well I would check craigslist to see what is out there, you can find a used one for 1/2 the price of a new one - just make sure everything is sound on it!;)
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
2601 can do a 4' or 5' with no problem!
while all of us like Kubota.... i went with the Titan in kubota orange for around $600... does an awesome job.
& it looks like this behind a 2601 & on its own..
Cathy Liebchen
KUBOTA L3901, MX5800, MULE PRO FX, MULE PRO FXT
if you are just mowing high grass and not any saplings, one of the light duty brands at under $1,000 with a simple shear pin will do fine. If not, go for a Bush Hog, Land Pride or Woods heavier duty with a slip clutch at the $1,000 + range. We run a Land Pride 1860 and it is a stout unit. We find the used ones for sale around here are almost always flogged out junk, or the cheaper brands
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
If you plan to leave it sitting out in the weather might look at Modern ag implements. They're galvanized so no worry about rust and they are very well built.
Ezlife45
B2650
Jun 5, 2014
172
Louisiana
I have a B2650 and bought a 4' bush hog with a slip clutch. I think I could easily have run a 5'.
I have a 26 hp engine.
